need more drive coming off...help please
  • bluemod
    • 214
    After changing the shocks around the car rolls over alot to the right side never had that much roll. found another problem in the rr bars rrbb was trailing almost an inch. The rrtb was trailing 1/2inch. So i set both to trail a quarter of an inch. On a 1/2 mile high bank track should you have to have alot of trail to make the car turn?
    • drtrkr244
      • Dec 2007
      • 1024
      Thats a good starting point.Some car builders put lead in RF, some RR.
      An adjustment I recommend for my customers, for more drive, is lowering RTB.Generally, ur not off gas too long, so it doesnt affect the entry.
      • JustAddDirt
        • 1893
        If you are on a small tighter 1/2 mile yes, but if you are on a bigger cornered track, I would say even up. You get more rear steer as the car gets up on the bars, and rolls over. Dont know if you need that extra 1/4" or not.
        Just have to feel it out and see.
        Also, How much stagger u typically run?
        • bluemod
          • 214
          we have to run tires from the track and the most stagger i can get out of the g60s are 2in in the rear and 1/2 an inch in the front. I cant find g60-15 anywhere to buy but the track
          • bluemod
            • 214
            we raced and the car was upside down. We swapped the shocks around on the front and shortened the rrbs a quater of an inch. The car pushed so hard is was bad it was like drivin a diffrent car than what i had.
            • JustAddDirt
              • 1893
              So now you have too much drive?
              did u put the 1/4" lead back in it?
              Did u raise RRbottom bar 1 hole?
              lower rr top bar 1 hole?
              might need to even up springs in front. 2 750's
              That will loosen up entry and through middle as well.
              • washeduptoo
                • 1353
                Are you squaring the rear end in the car or are you going by bar lengths to square, that might not work depending upon how it was built.
                • oldtrackchamp4x
                  • 270
                  Sounds to me like you are doing way to many things to the car at one time and now it's really off.I would put the car BACK to where it was when it was JUST loose on exit. Then just make ONE change at a time, like BITE or LLB or LUB. JMO
                  • bluemod
                    • 214
                    We took out the 1/2in trail in the rr. Did not move any bars. And swaped the shocks around.
                    Put it on the scales after the race and we got
                    this is weight at each wheel
                    lf625 rf 456
                    lr 699 rr672
                    same springs in same location
                    left%54.4
                    cross%46.6
                    rear%55.3
                    stagger
                    lf 83in rf84in
                    lr83in rr85in
                    Car would not turn going in just strait to the wall no matter where at in the turn and this is a sweepin high bank track. To me the right front weight seems alot low. please all thoughts to help
                    • oldtrackchamp4x
                      • 270
                      What were your scale numbers BEFORE you made any recent changes? From what you now have I feel your bite and cross are both low. I've never been on a high banked 1/2 mile, only 1/4- 3/10, so i might be talking out my rear, but I think you should raise your bite up to 70-80 lbs, which should loosen entry and tighten exit, but i would put the trail where it was, leave the shocks as they are now then scale then try the car. I'm assuming your ride heights are all correct and you are adjusting your weight jacks correctly to keep the heights the same. There are some way smart guys on here so i'm basically telling what has worked for me now and in the past. JMO Good Luck
                      • bluemod
                        • 214
                        lf625 rf 456
                        lr 699 rr672
                        left%54.4
                        cross%46.6
                        rear%55.3
                        stagger
                        lf 83in rf84in
                        lr83in rr85in
                        before was
                        lf617 rf501
                        lf 699 rr661
                        left%54.1
                        cross 47.2
                        rear%55
                        everything else the same
                        • bluemod
                          • 214
                          we swaped everything back to the way it was the last couple races when we were running good whats the easyest way to loosen the car up getting in
                          • charcoal01
                            • 545
                            Raise the right lower or add steer.
                            • bluemod
                              • 214
                              Will this have anyother effects on the car besides on entry? Also lowerin the j-bar on the frame puting more angle on it what does this do?
                              • xxxmod
                                • Jan 2012
                                • 111
                                More back brake,better back brakes,softer front brake pads.
