does the j bar need to run strait mine is not sitting in the car square and wondering if it could be binding
j bar help
If your talking about the frame end being ahead of the pinion end, yes, usually frame end is forward of pinion end.
You might want to check the 72 inches from motor plate to center line of axle tube. I think that is the correct measurement. Good luck.
4 bar left and its ahead at the pinion can develop a bind and interference with other components.The Blacksheep cometh ! With old bent sh!t that just keeps getting faster !
If it was mine I would run it as close to parallel with the axle as possible on 3 link.The Blacksheep cometh ! With old bent sh!t that just keeps getting faster !
