This is a general question that started in the shop. How soft can you go on front spring rates? Lets say the track is a big 1/2 mile with very little banking and sweeping corners. I know lates are getting really soft in the front. Just looking for ideas on pinning the right front.
How soft on front springs
Chevelle front stub stock lowers and no bump stop. Four bar car. Is there a difference between bump stop and no stop like just bottoming out the RF shock?
Bump stops run really soft springs so you are actually running on the bump stop and not the spring when the car rolls over.
Im trying a 450 RF, and 500 LF in my IMCA type modified this weekend. No bump stops. 1/4 Mile Semi-banked. Usually gets dry for features. Stock lower control arms, adjustable uppers. QA1 Balljoints.
4 bar/4 bar suspension with ford 9"
What should I expect?Last edited by bkriegle; 06-12-2012, 04:59 PM.
So is it possible to get into the 500- 450 range on the front of a modified? I know there is no magical set up and you just can't beat hard work and homework in the shop. Just trying to find out if it is possible for this to work.... get faster....win....
Run what your driving style suits. In order to be soft on the front end, you need to not be depending on a lot of forward traction, but more momentum. It is pretty tough in an IMCA Car (No blade in the back and no lift arm) to run less than a 500 in the RF.Curious that we spend more time congratulating people who have succeeded than encouraging people who have not.
I would often swap springs at the track depending one the shape of the track. If it was rough I would run a heavier spring and shock package. If it was slick and smooth I would run aonther combo. Some times I would even swap between the heat and the main.My sarcasm is a pre-emptive strike to your stupidity!!
springs
I would go as soft as possible, that way way everyone can brag to their fellow racers how soft their springs are.
Have any of you people ever figured the motion ratios, and what the soft springs rates actually compute to rate at the spindle? Then you put a shock on the RF with virtually no compression dampning, and a ton of rebound and hold the weight on the RF, when you do that, what spring are you unloading.....the LR.I think there should be lifeguards in the genepool.
If the soft front end doesn't work, you might get ahold of Jason Hughes, Ryan Gustin, Jared Landers and let them know that they can go a lot faster.Curious that we spend more time congratulating people who have succeeded than encouraging people who have not.
I would bet not.Curious that we spend more time congratulating people who have succeeded than encouraging people who have not.
