How soft on front springs
  • fastonraceday
    • Jan 2009
    • 10
    This is a general question that started in the shop. How soft can you go on front spring rates? Lets say the track is a big 1/2 mile with very little banking and sweeping corners. I know lates are getting really soft in the front. Just looking for ideas on pinning the right front.
  • usafracer
    • Jun 2010
    • 554
    Depends on what clip what control arms. I have run as soft as a 500 on the RF and 425 on lf. Metric clip with tube nova lowers.
    • dirttrackrocker
      • Nov 2010
      • 664
      Bumpstops or no bumpstops??
      • fastonraceday
        • Jan 2009
        • 10
        Chevelle front stub stock lowers and no bump stop. Four bar car. Is there a difference between bump stop and no stop like just bottoming out the RF shock?
        • dirttrackrocker
          • Nov 2010
          • 664
          Bump stops run really soft springs so you are actually running on the bump stop and not the spring when the car rolls over.
          • bkriegle
            • Oct 2011
            • 11
            Im trying a 450 RF, and 500 LF in my IMCA type modified this weekend. No bump stops. 1/4 Mile Semi-banked. Usually gets dry for features. Stock lower control arms, adjustable uppers. QA1 Balljoints.
            4 bar/4 bar suspension with ford 9"
            What should I expect?
            • usafracer
              • Jun 2010
              • 554
              Expect it to be very soft lol. You will have to drive the car with finesse. You can't go throwing it into the corners like a tank. Gotta be really calm an smooth.
              • fastonraceday
                • Jan 2009
                • 10
                So is it possible to get into the 500- 450 range on the front of a modified? I know there is no magical set up and you just can't beat hard work and homework in the shop. Just trying to find out if it is possible for this to work.... get faster....win....
                • TeamGRT12x
                  • 911
                  Run what your driving style suits. In order to be soft on the front end, you need to not be depending on a lot of forward traction, but more momentum. It is pretty tough in an IMCA Car (No blade in the back and no lift arm) to run less than a 500 in the RF.
                  • bkriegle
                    • Oct 2011
                    • 11
                    I decided not to soften mine right now. Last week the track had deep ruts in the center of the turns. I think going softer will only hinder the cars performance. Im still fighting forward bite problems, but thats a whole other thread.
                    • usafracer
                      • Jun 2010
                      • 554
                      I would often swap springs at the track depending one the shape of the track. If it was rough I would run a heavier spring and shock package. If it was slick and smooth I would run aonther combo. Some times I would even swap between the heat and the main.
                      • JustAddDirt
                        • 1893
                        springs
                        I would go as soft as possible, that way way everyone can brag to their fellow racers how soft their springs are.
                        Have any of you people ever figured the motion ratios, and what the soft springs rates actually compute to rate at the spindle? Then you put a shock on the RF with virtually no compression dampning, and a ton of rebound and hold the weight on the RF, when you do that, what spring are you unloading.....the LR.
                        • TeamGRT12x
                          • 911
                          If the soft front end doesn't work, you might get ahold of Jason Hughes, Ryan Gustin, Jared Landers and let them know that they can go a lot faster.
                          • dirttrackrocker
                            • Nov 2010
                            • 664
                            I would bet all those guys are running on bumpstops....
                            • TeamGRT12x
                              • 911
                              I would bet not.
