lose on mid/exit
  • bluemod
    • 214
    lose on mid/exit
    im loose mid-/exit and i found the reason. i have a 3/4 in trail in the rr. What i was wonding is i dont have a short enough bar to move the rr in where it needs to be so what will happen if i put rounds in the left side bars to compensate for the issue. thanks in advance
    If you have that much difference in wheelbase length, it isn't terrible. I would cut off the right hand thread end of your tube and tap it deeper. Use kerosene for a lubricant.
    • dirttrackrocker
      • Nov 2010
      • 664
      or just lengthen the LR a little
      • bluemod
        • 214
        I lengthened the lr to make it a 1/4 of an inch diffrence for this week. did i move it to much to start with?
        • dirttrackrocker
          • Nov 2010
          • 664
          Give it a try and see what you think..
