i have a dirtworks dw 11 i cant seem to to get any forward drive off the cornor on dry slick tracks my bar angles are left side is top bar 25 degrees bottom bar 5 degrees right side top bar 18 degrees bottom 0 degrees. springs are 650 lf 600 rf 175 arcoss the back. need help?
no forward drive
Ran a DW-8 for three years, had to run 60-70 lbs bite to get good forward drive. I don't know how good you are on throttle control, but on dry slick you have to be easy on the throttle. My car was setup real close to yours, including the springs, and it was good. JMO
what pull bar are you using ? and if biscuits size ,color,and age of them
Try putting 60-70 lbs of bite in it, if that doesn't help as much as you'd like try a 200 in the lr and add bite until it throttle pushes.
