running a saginaw in a mod up's and down's
  • bonk_87us
    • Feb 2013
    • 42
    ok ive ben doing alot of looking into this i know the brinn tranny is the best but i do not have $1500 to fork out right now on one this will be my first year in a imca mod and i also race street stock so i plan on raceing the mod with the 3speed tranny cause i already have them and a $600 clutch kit thats pretty much new so here is my car set up05 grt 4link ford floater bsb bird cages spring slider behind lr shock in front spring slider in front rr shock behind running a 90/10 shock with a toqr link with 700lb to 1500lb progesiv spring solid motor mountsi was told that a 3speed will not work but ive seen post and cars for sale with them so i say it will work till i get fundings to get a raceing tranny my plan after ive looked at other sites i took my tranny draind all fluids and stood it stright up took side cover off and took the tail shaft out then removed the casing the shaft was only splind up to 4 1/2 inches then about 1 1/2 inches past the splines there was a hump in the shaft stoping the 8inch yoke from travling the whole way in so i took the shaft and had it put on a metal lathe and turnd it down just enouf so that the yoke could get full travel and now it does put it all back together and put tranny in car now i need to get the right length drive shaft for the car i got the 8inch yoke but how much of that yoke should i let stick in the tail shaft so i can get my drive shaft lenght my car sits with 7degree pinon angle i just need a good idea on how much the yoke should be sticking in the trans so i can get the drive shaft orderd and my yoke is the new style 8inch that is hollow the whole way threw so if its gonna bottom out it will bottom out on the pat of the yoke where the u-joints go and hit the tranny case where the seal is not where the splines are sticking out the back of the tranny am i going the right rout with this just keep in mind this is about useing a saginaw so i need info on that part i will get a brinn or falcon latter down the road when the time comes thank you all
  • Egoracing
    • 4852
    Are you running a steel bell housing? If not you need to!
    • mudeater18
      • 1599
      Sell that stuff to someone in a class that is required to run it. Buy a used Bert for around $750. You'll be glad you did.
      • powerslide
        • 2696
        I think you should follow mudeaters advice, but i would buy a brinn not a bert.
        You need 2, 2 1/2in inside the trans at ride height.
        • jsf74
          • 544
          Pros= nothing
          Cons= after u buy everything to make it work is about the same price as a Bert.
          Good mini clutch
          Shifter
          hydraulic throw out bearing
          Bell housing
          Remove 1st gear lighten
          It weighs a ton
          eats horsepower
          Not as strong
            Pro- less lead
            • johnny v
              • Mar 2011
              • 197
              con- weight where you can't place it where you want too...
              see ya
              johnny v
              • Racer111
                • 796
                Engine will rev faster with a bert brinn setup
                • dirttrackrocker
                  • Nov 2010
                  • 664
                  As everyone else said, there are no positives and a whole lot of negatives. If you can't afford a Bert/Brinn/Falcon you shouldn't be racing a mod. Harsh, but, true.
                  • jsf74
                    • 544
                    I'm slowly learning you try to cheap out on something it's gonna cost three times as much in the end cause you'll end up braking replacing and braking again. After all the wasted time and money you end up buying the right part in the end. Yeah I'm guilty.
                    • racin6mod
                      • 2172
                      just watched a used bert sell on ebay for $440.00 most are from 550 up to 750 used in my area.to buy a sagnaw set it's 100 for trany used 75 up for hydro throwout bearing,250 up to 375 for a good used triple disc clutch. and 75 up to 325 for a steel bell housing. around here sport mod have to run 3 speeeds so it drove the prices back up so as stated before if you have the parts sell it and put that money toward a bert. bert are cheaper to get into and will hold up fine.they're the sbc of the trany world.
                      • bonk_87us
                        • Feb 2013
                        • 42
                        tranny
                        this is to the dirttrackrocker you can keep ur smart a$$ mouth shut not everyone was borin rich or sponcers fall right in your hand its not that i dont have the money to buy the tranny im just sittin on 5 trannys now and i race street stock and hobby stock right now i just got the mod as the 3rd car and ive ran sprints for 5 years on top of all that and payed for everything out of my pocket with no sponcers so you know what you can kiss and suck IF I HAD THE SPONCERS OR IF SOMEONE PUT ME IN THERE TOP OF THE LINE CAR I WOULD SMOKE YOUR A$$ IN A HEART BEAT AND YOUR SCREEN NAME WOULD GO TO DIRT DUD RACER I KNOW ITS BEST TO RUN THE BRINN BUT THAT WAS NOT WHAT I WAS ASKING IN THE POAST TO BEGIN WITH
                        • boogityk5
                          • Dec 2011
                          • 41
                          I'm right there with you bonk, took my engine and 3spd out of my hobby stock and put it in an older 4bar mod. I've got about 10 races since last fall with no apparent issues. Solid motor mounts with a midplate, and a steel bellhousing. Good luck!
                          • bonk_87us
                            • Feb 2013
                            • 42
                            yep
                            yep there is always a way the whole point was just useing up what i have in my shop insted of letting it collect dust i already have 2 light weight clutch setups that are pretty much like new all the wanna be hot shots can go eat there steak dinner and go spend there $ or there sponcers $ on high $ parts and bold them on they just dont wanna get there hands greasy and put a little work into somthing i work my ass off just to do what i love doing and work till my hands bleed then you got some smart rich ass trying to tell you how to do it with bolt on parts id rather crank up the music spend hours in the shop working on my race cars than go out eat dinner and listin to some cranky ass rich wife i realy dont care what they say bout the weight they try to save my engin dyno at 610hp 358limit late model enging going in this mod and im not worried bout a little extra weight haveing a clutch in the car when you can only run a 8inch wheel you got thes rich guys out there running there money around a track that the car cant handel all there high$ parts and flying apart spinning tires and waveing to the in field with there left front tire all they do is show off and lose track time anyway i like my car with all 4 on the track thats the way it should be ive seen so manny hot shots spend ton of money and get there a$$ takein down by back woods racer manny times where i come from i kill my food drink my beer and work my ass of just to race on the weekends mabey someday ill get some sponcers to help me out with somthing i work and also work on my cars pretty much my self i do all my engine building my self just to save money ben building engines for 15years dirt and drag and non never left me down other than a faultie part so MR know it all kan kiss my hard workin poor A$$ you know what i meen
                            • Egoracing
                              • 4852
                              There is not a light weight clutch alive that will accelerate with a direct drive transmission. No one is talking being rich, If you looked around you could sell what you have, put a Brinn in and have $$ left.
