3 Link
  • 7uptruckracer
    3 Link
    Heavy Track car is tight on entry have to run three wheel brake. Looking for advice on how I can change the rear spring configuration (coilovers both on front) to help as well as maybe shock valving i'm 4-6 LF 3-7 RF 4-4 LR 3-3 RR It a 3 link on j bar with a solid link (do have spring loaded as well)
    can i run more compression on the LR to hold Rear Steer in it or will it hurt more then it helps? Is the solid link not wrapping hurting me? its Low HP so I can't afford to absorb much accel torque
  • Towers21
    • Oct 2012
    • 63
    Too Tight
    I would start out fairly simple. Move wheel offset. Either RR out or LR in or both if bad tight and work with wedge. Move the wheels or wheel and get a base line then try X- amount of bite out of it for heats and then maybe look into some other scenarios. I wouldnt chase shocks till you were closer. Hope it helps. Where are you running?
    • Dirt Knife
      • Jun 2012
      • 147
      Front End
      What are your front end settings?
      bottoming out
      are you running stiffer LF than RF spring like 750 LF and 700RF
      maybe your front shocks are too heavy for your springs?
      Try a pair of 5's up front no split
      or put your LF on the RF and run a straight 5 on the LF
      Just some thoughts
      • junebug
        • 363
        With rr spring in front car shouldn't be tight on entry becuz your unloading rr...makes me think u have a roll steer issue...id raise the rr bar up if u can
        • 7uptruckracer
          I'm thinking rear steer as well I didn't get to specific on springs because its a pro 4 Mod on coilovers just running by some principals to help me figure it out. Its still a three link rear on 17" trailing arms. I'm running 6* LR angle and about 5* RR angle which i think is the issue. I have to be careful about rear steer with my trans and yoke because its not an aftermarket with a long output shaft. I'm 130 bite 150 RR 200 LR both in front on coilevers 23* top link in top hole on rear on a afco torque link with a 3700# brake spring and a 1200 accel spring. 300 LF 375 RF 54% LS weight and 50% rear I just converted it to jar bar from 36" rear panhard bar. Car was close at the end of the year on three wheel brake. I think I need to start around 18* LR Bar and 10-15 on the RR. Should I run a high compression LR to keep rear steer in it and not let it set down?
          • junebug
            • 363
            I would definitely say u need more left side angle..i think 6• on the rr is prolly pretty close id go bout 17-20 lr and 6 rr if u can get that much in lr
            • Dirt Knife
              • Jun 2012
              • 147
              J Bar
              By moving your panhard bar to the front of the pinion
              going into the corner it is now falling
              last year it was behind the rear end rising going in
              so for a tight condition going in I would say
              raise the J bar on the pinion 1/2"
              If you were close last year this will get you to where you were
              • 7uptruckracer
                Last year was a 36" behind the housing LS AXLE Mount and RIGHT side Frame Asphalt style So chassis didn't hike....it was a pain but I finally got it to handle pretty good on three wheel brake enough to be running up front just need the extra..... changes. Why not more RR angle I've seen old mod three links on 15" bars run 10-15 and I'm on longer bars.
                • 7uptruckracer
                  Since last year I've also dropped the front roll center from 3.88 high to 2.50 High and changed my RF camber curve from losing a fair amount of camber through dive and roll at -3.5 camber on the RF to -5 static and i actually get back to about -5 after dive and roll going from a 9" arm to a 7.5 in arm and its a slugged arm so I don't get much caster change. bump is around .50 at 2'. LF I was around 2* camber and have gone to 4* All since last year So this all should help entry! What is everyone opinion on Solid vs. a moving torque absorber as it pertains to my issues I know axle wrap is non existent with a solid link.
                  • powerslide
                    • 2696
                    how much trail are you running? Maybe just try rolling the RR back a couple turns. Might try running the RR spring on top i felt like it helped carry momentum more so than rr spring in front. But try pushing the RR back a 1/4in and see if that cures any of it
                    • oldtrackchamp4x
                      • 270
                      In your post you said last year you were running up front, but needed a little extra. Not a three link guy, but you made numerous changes to car when , in my opinion, the car was very close on setup last year. Might be easier to make car better by going back to what you had last year and just make small changes from there. As always. JMO.
                      • 7uptruckracer
                        It was running second but having to run 3 wheel brake and the manner I had to drive it in wasn't really ideal. I'm really leaning to Roll steer with that old bar being so long all you were really relying on was the RR bar angle and coilover for any rear steer the LR didn't move at all, It was really an asphalt style rear suspension setup
                        • junebug
                          • 363
                          how much rr travel are u getting now...if your rr bar is really flat at ride height its probably going past center and taking steer out of the car on entry...i would at least get it steep enough so it never goes below 0•
                          • 7uptruckracer
                            I typoed its a 18" c-c bar I get about 3" travel I've taken the spring off and it ends up just about level never below but my thinking is with such a long bar I might not have enough static angle and I run my RR back about a 1/2" of trail. What are the thoughts on solid pull bar won't the rear end not wrapping down as far as the RR shock is concerned not let it unload but the trade off is one thats spring on Decel makes it tighter if you absorb the rear end unloading.......it might all be solved when the Jbar and a car that actually rolls up the LR on entry, just trying to get it as close as possible before it gets there
                            • junebug
                              • 363
                              I thk solid pullbar is ok...idk if u could get away with rr in front if u didnt have it that way...i think possibly more rr compression or RF rebound...either one holds steer in the car better on entry
