Mechanical Gas fuel pump???
  • Flyin Iowan
    • 558
    Whats everyone running?
    With or without regulator?
    Have the Carter billet pump(blue) no regulator, 5-6lbs pressure at full throttle. Need something to get me more.
    Thanks
    Chris Zogg
  • Racer96m
    • 425
    CV Billet bump, 7-8 psi no regulator. Last pump you will ever buy.
    Dave
    • Egoracing
      • 4852
      Are you leaning the engine out? 5-6 should be enough.
      • Flyin Iowan
        • 558
        plugs are snow white. carb is set rich. never had this problem until I got this pump, actually this is the second one. its rated 6-8 never goes above 5 sent it back and got another and its the same. this one goes 5 1/2 some times.
        Chris Zogg
        • Flyin Iowan
          • 558
          plugs are snow white. carb is set rich. never had this problem until I got this pump, actually this is the second one. its rated 6-8 never goes above 5 sent it back and got another and its the same. this one goes 5 1/2 some times. It never moves more then 1/2 lb from idle to 9000RPM
          Chris Zogg
          • TALON75
            • 887
            Might wanna double check push rod length , or you can get higher pressure springs from cv(I believe they make that carter blue pump).
            www.RACE91.com
