Pierce Clamped 3 hole car
  • tworrick
    • Oct 2011
    • 135
    We are having a problem with the car wobbling back fourth in the corner. It goes back fourth lays over on right nice and then back on left looks like a motor boat. . The rear does. normally run 225 rr 200lr have run 250rr 200lr in hopes to stop the problem. s this a shock problem ? The best cars lay over and stay stable . was thinking about like a 8-2 lr shock to keep it from going back on left . or maybe more hold down shock on rr? Please help .
  • Racer111
    • 796
    Whats the front springs? Is it goin back and forth on rf lr ? Sounds like a bad shock.
    • tworrick
      • Oct 2011
      • 135
      Normally 650 ref 700 lf yes same thing I was thinking. It is in the rear of car right to left.
      • racin6mod
        • 2172
        I was thinking bp cars ran a 225 to 250 on the lr and a 200 rr maybe try a 175 rr or raise the lead to help keep over on the rr.
        • tworrick
          • Oct 2011
          • 135
          Har ran 200 on both . but pretty heavy at times rough tracks around here. So we stiffened rr some . You might be right though. just not sure how would be in bumps
          • BPRC MAN
            • Apr 2012
            • 156
            On our Bp we ran 225 lr and 200 rr and raised the ride heights 1/2 inch and worked great on pretty much any surface.
            • tworrick
              • Oct 2011
              • 135
              Did you raise up 1/2 all the way around or only in rear?
              • BPRC MAN
                • Apr 2012
                • 156
                Only the rear and ran about 60 lbs of bite
                • JustAddDirt
                  • 1893
                  the problem is the car is po-going on the straight panhard bar. J bar will help. or take out panhard bar angle.
                  • xxxmod
                    • Jan 2012
                    • 111
                    Your springs are fine, yes to the 8-2 and yes to a j bar rather than a
                    short LS panhard. 18 to 19" jbar
                    • tworrick
                      • Oct 2011
                      • 135
                      Shocks helped this weekend. We have had poblems running the 8-2 shock on lr. We have the spring cup holder and we forgot to zip tie the spring in . So the spring pops out with that lr shock . Cause iin the corner that spring comes completly out of the cup holder. I believe when this happens makes the car very loose in center. hurts side bite. Take your lr spring out entering the corner and can not be a good thing. Does anyone run a taller spring in lr to help this problem . If you do that does it change the spring rate .
                      • washeduptoo
                        • 1353
                        I know nothing about a BP car but trying to understand your problem. Your running a clamped up spring in front lr and you have a shock thru it? How long is your spring? Sorry I'm not much help just trying to understand what is happening because we've ran a clamped up car before but the shock was behind.
                        • BPRC MAN
                          • Apr 2012
                          • 156
                          Make sure that your clamp bracket hasnt spun on the axle tube.On our 08 bp we had that happen a couple times where the spring side gets pushed down and allows the car to have to much hike which unloads that spring to far.
                          • tworrick
                            • Oct 2011
                            • 135
                            isn't the clamp bracket tapped into the rear end with a bolt?
                            • tworrick
                              • Oct 2011
                              • 135
                              Shock is mounted on rear of axle on same braket as Spring holder. The spring sets in a cup . then the upper is another cup holder with a wedge bolt. So on left rear when car is on full lift the spring really has nothing holding it in .
