BPRC MAN How can you tell if it is low? with an angle finder should it ne lever ? or is there a measurment?
Pierce Clamped 3 hole car
When you set your clamp/shock mount the rear should be at full drop and rotate the bracket so the shock has at least 1 inch of extension left in it for axle wrap.tack weld to housing . Try to get the car set up so the cup does not come off the spring more than 1.5 inches at full drop.a taller spring will not help unless you have coil bind or your screw jack doesnt reach
Thanks for the information, that is the way ours was except we had a slider in the spring. We also started running the shock on the back on the b/c and it seemed to help car. Thanks again.
