Left side heavy
  • crateracer16
    • Apr 2009
    • 332
    Left side heavy
    06 bms 4 bar chevelle front clip. 700rf 650lf 175lr,spring behind. 150rr. No weight on car. Stuck at 56.1 left side % and only 51.6% rear. Cross and bite is good. Ride heights are also good. How can I pull some of the left off and get it to the rear and not mess up my bite. Thanks.
  • dirttrackrocker
    • Nov 2010
    • 664
    The only way to add rear % is to physically add weight to the car
    • racinjj
      • 98
      You will have to physically move weight on your car to change left to right and front to rear weight. When you are done with that you will have to readjust your screw jacks and coil over eliminators to get your bite and cross weight back. That seems very heavy on the left, is that with the driver, how heavy is the driver, how heavy is the car.
      Sounds like you will need to stick weight in the right rear of the car. Also, what wheel offsets are you using?
      www.UltimateRaceCars.com
      • crateracer16
        • Apr 2009
        • 332
        That's without driver but with 75lbs in the seat because I weigh 285 and my setup sheets are for a 210lb driver. The car without driver is 2112lbs with about 15 gals of fuel. 2" offset on rf and lf and lr and 3" on rr.
        • MM90
          • Oct 2010
          • 422
          I would make sure your cables aren't crossed on the scales you are using. How big is the fuel cell? What engine are you running? If you don't have a problem with your scales then you need to add some lead to the rear and right side of the car.
          • crateracer16
            • Apr 2009
            • 332
            Cables are good. Rolled my other car on them right after this one and she came out perfect. Fuel cell is a 32gal rectangle. Engine is a 418sbc with alum heads.
            • dirttrackrocker
              • Nov 2010
              • 664
              Fill it with fuel and start hanging weight on the RR
              • setup479point2
                • Feb 2013
                • 188
                No way a bms is that percent , even with the weight in the seat . With my 285 lb. driver in the seat we don't have that much left . The rear is way off also. Try another set of scales , and definitely call bms.
                • junebug
                  • 363
                  something is definitely way outta wack...ive never seen any modified even capable of getting close to those numbers
                  • racin6mod
                    • 2172
                    check the springs we had a couple springs throw the set up off once and maybe a shock or something binding up.
                    • setup479point2
                      • Feb 2013
                      • 188
                      This will not change left or rear percent , it will cause problems with scaling. You can't change left or rear percent without physically moving weight location.
                      • crateracer16
                        • Apr 2009
                        • 332
                        Put the car on another set of scales and same numbers. Can't move the cell. The cage it's in isn't designed to slide. The battery is already on the right side. How much should I hang to get the rear % up? Are talking 50lbs or more?
                        • junebug
                          • 363
                          hmmm that's really crazy numbers....i would check alignment of the rearend...maybe it is shoved way to the right...other than that im not sure how you'd ever get over 55% at most left side
                          • crateracer16
                            • Apr 2009
                            • 332
                            Ya. I'm pulling my hair out over this thing. I tried 2 different sets of shocks and springs just o make make sure nothing was bent and no change. I can get the left down to about 55% but then I have low cross numbers.
                            • setup479point2
                              • Feb 2013
                              • 188
                              We have an 06 bms , with recommended fuel in car and 20 lb weight , no driver it's over 56 percent rear. To get 51 percent in one of these you'd have to have moved the engine forward about a foot , and I don't even think that would do it. Left percent could be rear to far to right as suggested above. Again call BMS , they will gladly help. Also left and rear percent have nothing to do with cross , you can get any cross with any left and rear.
