i talked to him last night, man it was nice finally getting a hold of someone who cared. thanks for the link
Left side heavy
Got the car setup a lot better now. Moved some stuff like Joel said and she was on a rail last night. Thanks fellas.
Can't give away secrets. J/k. Rear end was to about 2" too far to the left. The biggest problem was a birdcage was bound up bad. It was a brand new bearing cage and somehow came messed up from the factory. I had to put about 45lbs of weight on rr. They also said it was ok to be down around 54% rear percent.
Thank you it may help a fellow racer down the road. We knew something was bad off based on your numbers.Originally posted by crateracer16 View PostCan't give away secrets. J/k. Rear end was to about 2" too far to the left. The biggest problem was a birdcage was bound up bad. It was a brand new bearing cage and somehow came messed up from the factory. I had to put about 45lbs of weight on rr. They also said it was ok to be down around 54% rear percent.
Sorry. Said two things at once. It was out right and I moved it left. The cage was getting stuck foward when i jacked the car up, so it pushed it back into the spring when I set the car back down. I started having too much wedge and thats how infound the cage. I changed cages and I had more rf wheel weight and less left side. Then I moved the rear end over 2" and added the 45lbs to the rr and then it brought it down to where I needed it.
