on a dry, dusty, slick track do you want more left rear bite or less???
question about clamped up pierce setup????
do you have a 90-10 axle damper shock on?
are you running a 4 link on RR or z-link?
straight panhard bar?I think there should be lifeguards in the genepool.
move rr wheel in. move lr wheel out. soften lr spring. readjust wedgeModern Day Spec Wedge Racing
If you put on a 90-10 that will snug up entry.
might drop rr lower bar one hole. that will tighten all the way threw corner.
try a 225 on LR. it should tighten on throttle
4" offset RR wheel will help too
Do you have a limiting chain on the RR?
I have seen clamp cars that are on the 4 link right side, spring on birdcage, and on axle tube, try to climb the bars on the right side.
Which will try to plant RR tire middle off corner, and down straight.I think there should be lifeguards in the genepool.
Just my two cents and it may not be worth much but 550 seems like a pretty soft ref spring for a clamp car. We always had good luck with 700lf 650rf and 225 across back. If the car is loose all over you may want to think about taking some lead out of the rear end.Broc Burton
go.fast.crs@gmail.com
a 3in right rear will also rub on the zlink bar , it calls for a 2in rim all around the car, if you stay with pierces book you should be close. if your running a short bar it should be center of yoke or 1 hole above. j bar center to yoke or 1 hole below.
