question about clamped up pierce setup????
  • ump29
    • 231
    on a dry, dusty, slick track do you want more left rear bite or less???
    • 14306
    If you are loose in and tight off, then less. If you are tight in and loose off, more.
    A floated lr behind deal will get you hooked up better.
    • ump29
      • 231
      it gets loose in and losses drive off... i haven't been able to find and adjustment to help yet... it is not terrible, just needs more drive off ..
      • Racer111
        • 796
        run pull bar spring loose put 3inch wheel on rr more tail weight less stagger what springs are you running?
        • anissa5
          • Jul 2010
          • 79
          How will a 3in on lr help will it tighten the car
          • JustAddDirt
            • 1893
            do you have a 90-10 axle damper shock on?
            are you running a 4 link on RR or z-link?
            straight panhard bar?
            • ump29
              • 231
              no 90-10, 4 bar both sides,, j- bar 1inch below pinion, springs lf 700 rf 550 lr 200 rr 225 ... 80 lbs bite. 57% rear 52% left 50% cross
                • 14306
                move rr wheel in. move lr wheel out. soften lr spring. readjust wedge
                • JustAddDirt
                  • 1893
                  If you put on a 90-10 that will snug up entry.
                  might drop rr lower bar one hole. that will tighten all the way threw corner.
                  try a 225 on LR. it should tighten on throttle
                  4" offset RR wheel will help too
                  Do you have a limiting chain on the RR?
                  I have seen clamp cars that are on the 4 link right side, spring on birdcage, and on axle tube, try to climb the bars on the right side.
                  Which will try to plant RR tire middle off corner, and down straight.
                  • BPRC MAN
                    • Apr 2012
                    • 156
                    Swap the rear springs and run the 90 10
                    • ump29
                      • 231
                      everyone says a 90-10 will help with entry but will it take anything away on exit...
                      • Renegade Cust Susp
                        • 349
                        Just my two cents and it may not be worth much but 550 seems like a pretty soft ref spring for a clamp car. We always had good luck with 700lf 650rf and 225 across back. If the car is loose all over you may want to think about taking some lead out of the rear end.
                        Broc Burton
                        go.fast.crs@gmail.com
                        • Racer111
                          • 796
                          Unless have a newer car a 4 inch wheel wont fit on rr only a 3 inch.
                          • bob75
                            • 2814
                            a 3in right rear will also rub on the zlink bar , it calls for a 2in rim all around the car, if you stay with pierces book you should be close. if your running a short bar it should be center of yoke or 1 hole above. j bar center to yoke or 1 hole below.
                            • ump29
                              • 231
                              thanks guys for all the feedback.. will let everyone know how it goes and what works.. thanks again...
