Roll over on right rear
  • hockey3266
    • Dec 2010
    • 65
    What could cause a car not to stay on the right rear when your in the throttle in the cornors? When i get in the cornors the car rolls over but when i get back into the gas it jacks the lr and rr up as well what can i do to keep the rr down so the car will create roll steer?
  • speedbuggy
    • 259
    take angle out of the upper RR bar
    • clbaker25x
      • Oct 2013
      • 85
      Most chassis builders run a chain on the right side to keep the car from jacking there.
      • hockey3266
        • Dec 2010
        • 65
        speedbuggy.....I Only have 18* in the upper rr bar which isnt alot?
        • powerslide
          • 2696
          Are you on pullbar or liftarm?
          • hockey3266
            • Dec 2010
            • 65
            pullbar and powerslide i sent you a pm to call me and this is about a differnt car we have
            • powerslide
              • 2696
              Get off work in 30 will give you a call then.
              • thinkstomuch
                • Sep 2013
                • 231
                Maybe take some index out of right rear bird cage?? not sure if this would work for all applications
                • LFMotorsports
                  • Feb 2010
                  • 247
                  Just a thought but what rebound do you have in the shock? If you have a low amount of rebound, it will not hold the weight over on the RR. Might double check that the shock doesn't have a "dead spot" and needs rebuilt if possible.
                  Something to think about.
                  • sideways
                    • Feb 2010
                    • 32
                    Check rebound in RR shock. How stiff RR spring are you running?
                    • hockey3266
                      • Dec 2010
                      • 65
                      200 rr spring 4-5 base vavle shock
                      • speedbuggy
                        • 259
                        If all you're really after is roll steer, why don't you put more angle in your RR lower bar?
                        Have you tried anyone's suggestions yet? Just wondering if anything helped or hurt.
                        • hockey3266
                          • Dec 2010
                          • 65
                          My car already has all the things they mentioned have the rr cage indexed at 0 rr upper bar angle is at 18* and you dont really want to go under that. and my shock isnt dead..... roll steer isnt really what im after because if i fix the problem the car will create roll steer....When i pick up the throtle in the corner the rr picks up like the left rear instead up digging creating side bite and roll steer...Since the rr is jacking up im losing roll steer...thought about chaning down the rr but really didnt want to have to do that!!!!!
                          • 7uptruckracer
                            Z Link Is sometimes used depending on your arrangement to effect this or more RR rebound
                            • powerslide
                              • 2696
                              Is the pullbar centered inbetween the tires or closer to the RR? I would try moving it towards the LR either way see if it helps. Phillips used to have a late model that always picked up on the RR, watched him out run us alot w/ that RR up in the air.
