Roll over on right rear
  • 7uptruckracer
    #31
    You will gain forward drive in a sense because the RR will have less drive so it will be tighter on exit. On the LM we set it to catch when the spring comes 1" off the collar I'm not sure the Modified procedure. Works the same way limiting RR upper bar angle.
    • ChadJacks
      • Sep 2012
      • 39
      #32
      Your car, just like any other modified, is getting on the bars. Its normal for your RR to hike up just like your LR. Attached is a video of our modified, look at the RR spring. Does your car wash out coming out of the corners?
      • 7uptruckracer
        #33
        I'm sure hes up that high because Clarys has been a rut fest lately. It looks somewhat normal to me the only difference and maybe thats where it feels different to me is the guys on rails have it on to the RF more just gives it that different attitude. I'm not sure if a chain would even cause much difference here Clarys barely gets past tacky it blows off sometimes. A chain might make it way to tight.
        • hockey3266
          • Dec 2010
          • 65
          #34
          yeah well since the car is going on the right rear its effecting me majorly on entre like i cant turn under throttle i have to get out and use the brake....its like this on every track not just clarys
          • hockey3266
            • Dec 2010
            • 65
            #35
            car is not going on the right rear***
            • 7uptruckracer
              #36
              Hmmmmm hit me up on FB maybe we can find something there I sent you a thing earlier.
              • oldtrackchamp4x
                • 270
                #37
                Stock Car Driver, Thanks for pointing out my miss type.It should have said RR. Still JMO.
