straight bar
  • chasefrehley
    • 134
    straight bar
    Where on the pinion do I mount my straight bar?
  • washeduptoo
    • 1353
    QC or 9in? On a QC we ran it 1.5-2 inch above center of pinion, on 9in center of pinion. Good luck
    • bob75
      • 2814
      if it has 4 holes on the pinion, run 2nd from the top
      • chasefrehley
        • 134
        I have a quick change. Thank you for the help
        • bob75
          • 2814
          thats what i run on my quick change (pierce car)
          • chasefrehley
            • 134
            i have a coyote.
            • bob75
              • 2814
              it will work, start it were i told ya.
              • chasefrehley
                • 134
                what is the length of your bar cent to cent?
                • bob75
                  • 2814
                  15inches thats a base line but check it to your side by side .mine is 14 5/8
                  • chasefrehley
                    • 134
                    My bar is 17 3/4 cent to cent. That puts my drive shaft center to trany
                    • Anonymous24
                      • Jan 2014
                      • 253
                      straight bar
                      All of those answers are wrong. Set car to ride height with the straight bar removed. Maintain pull/lift bar length and pinion angle to proper settings. Make sure RF and RR hub plates are in line with each other. Use the hole on the pinion plate that is on the axle centerline andmeasure its heighthfromnthe ground. Set the panhard bar chassis mount at that height so the bar will be level. Measure distance from chassis mount to axle mount. Your bar should be that length center to center. Install bar. That's not being technical because to be realistic it all depends on your front suspension in dynamic
                      Find me on Facebook: Impetus Dirt Racing Technologies
