With everything in neutral on a 4 Link chassis, what changes could be made to keep the LF on the race track?
Carrying the LF wheel
IMO.....The rear tires are hot because you are lacking traction. A tire that is hooked up will remain cooler than one thar isn't.Find me on Facebook: Impetus Dirt Racing Technologies
Also if your front to rear balance is off fronts won't be as hot could also mean you need to add toe out its not uncommon on hard tires so your heat balance stays the same after a few laps which also makes your handling stay more consistent through out the race
Full of fuel with driver in car 53.2%Rear tire temps LR 100-105 uniform across the contact patchRR 110-115 uniform across the contact patchRF tire temp 80-85 uniform across the contact patchLast edited by Anonymous24; 04-26-2014, 01:17 PM.Find me on Facebook: Impetus Dirt Racing Technologies
We have very little tire slippage. The suspension geometry is configured to help turn the car without needing to slide the car.Originally posted by MasterSbilt_Racer View PostHooked tires, that are slipped to turn the car, will be hot.Find me on Facebook: Impetus Dirt Racing Technologies
That isn't operating temp for a lot of dirt tires.Originally posted by Anonymous24 View PostFull of fuel with driver in car 53.2%Rear tire temps LR 100-105 uniform across the contact patchRR 110-115 uniform across the contact patchRF tire temp 80-85 uniform across the contact patchModern Day Spec Wedge Racing
Those were the temps from Friday right after the feature. I use a high quality pyrometer and check tire temps after every run. Car was very fast.Find me on Facebook: Impetus Dirt Racing Technologies
Are you also greenmod and accidentally logged in under your other screen name? It makes no sense for you to be posting your temps in a thread that has nothing to do with you?Originally posted by Anonymous24 View PostFull of fuel with driver in car 53.2%Rear tire temps LR 100-105 uniform across the contact patchRR 110-115 uniform across the contact patchRF tire temp 80-85 uniform across the contact patch
I realize most of your posts are worthy of someone who must be anonymous that's why Im asking not just assuming...
