quick fuel carb question
  • thrill22
    • Oct 2012
    • 102
    have a 750 quick fuel alky carb and the front float gets stuck it it sits, is there anything I can do to stop this, I her run gas through it helps?
  • mod71m
    • 393
    Replace the needle and seat
    • bob75
      • 2814
      after every race take one of the lower bowl bolts out drain the carb , then fill the carb bowls with gas, alky is a very dry fuel, will stick the needle and seats.
      • thinkstomuch
        • Sep 2013
        • 231
        i have the same issue with the same carb. the needle and seat need to be specific for alky, this is very important. other than that every couple weeks I take the needle out and clean the area and drench it with WD-40. seems to help
        • cavemod
          • Jan 2010
          • 135
          I agree with bob75 alky evaporates and leave that white residue which gums up everything in carb,not to mention the fact if carb is full of gas no need for the ketchup bottle to start it the next time you want to run the motor.
          • oldtrackchamp4x
            • 270
            Do you use lube in your alky? I use lube and haven't had that problem. Knock on wood. JMO
            • Dirtrunner35
              • May 2010
              • 632
              no problems, yes i use lube in fuel
