If you have good side bite but loose drive off as night goes on will a stiffer rf spring help if you keep good side bite? I usually sofen the rf and loose all drive while on throttle, wondering if i could stiffen rf to gain drive off??
RF spring and handling??
You will gain drive off and lose sidebite. You will have to try it to see if sidebite loss is critical. I have seen 50# lf spring softening kill sidebite before. Your car could react very negatively to increased rf spring.Originally posted by fastford02 View PostIf you have good side bite but loose drive off as night goes on will a stiffer rf spring help if you keep good side bite? I usually sofen the rf and loose all drive while on throttle, wondering if i could stiffen rf to gain drive off??Modern Day Spec Wedge Racing
