RF spring and handling??
  • fastford02
    • 153
    If you have good side bite but loose drive off as night goes on will a stiffer rf spring help if you keep good side bite? I usually sofen the rf and loose all drive while on throttle, wondering if i could stiffen rf to gain drive off??
    • 14324
    You will gain drive off and lose sidebite. You will have to try it to see if sidebite loss is critical. I have seen 50# lf spring softening kill sidebite before. Your car could react very negatively to increased rf spring.
    • dirtracr33
      • 278
      go with the stiffer rf and bump up rr 25
      powerslave
      • drtrkr244
        • Dec 2007
        • 1024
        Softer is normally better in the slick. Try dropping right top bar 2 holes for more drive and/or right bottom for more side bite.(1/2" holes, 2 degrees apart)
