Brake Bar
  • hasben
    • 38
    Brake Bar
    If you are running a short straight pan-hard bar would there be any advantage by putting a brake bar (not a torque arm - 5th coil lift bar) on the car too? Thanks
  • Cheatah19
    • Dec 2014
    • 5
    Yes. It will make the car more stable on corner entry. Just check your rules before doing so. Most state that you can only run one torque absorbing device.
    • hasben
      • 38
      This is just an arm with a chain to limit pinion angle and it only works when on brakes. Thanks most inspections around here are pretty lax.
      • Cheatah19
        • Dec 2014
        • 5
        It will still make entry more stable when used with a pull bar. You have to take the brake bushing off of your pull bar when doing this.
        • hasben
          • 38
          Thanks, we will try that.
          • washeduptoo
            • 1353
            Why do you take the brake bushing off pull bar? We have run the brake bar but no one told us to remove that bushing? Thanks
            • Cheatah19
              • Dec 2014
              • 5
              Leaving the brake bushing is defeating the purpose of having the brake bar
              • washeduptoo
                • 1353
                Thanks for the information.
