Bmod setup help
  • dirtracer07x
    • Aug 2014
    • 101
    Car was better with changes but still tight on entry. Also can somebody explain the panhard bar to me? Right now I am level with pinion and 8in up on frame.
    • oldtrackchamp4x
      • 270
      Typically speaking, dropping bar on pinion side or raising on frame side tightens entry to the center. Doing the opposite will loosen entry to center. Measure your split from ground to center of bolt on both ends and see what your split is between the two. Anywhere between 4-6 inches is pretty standard. I kinda think you have too much split for your car. JMO
      • dirtracer07x
        • Aug 2014
        • 101
        Well I redid the RR bracket and go 18° of bar angle and the car is finally good on the gas. Little loose getting in Noe but boy does it turn good lol
        • dirtracer07x
          • Aug 2014
          • 101
          Sorry lr bracket. Car is free now and great mid to exit but loose in
          • Dirtmod13
            • Jan 2014
            • 245
            Lighter RF spring will take some of the wedge off the LR when entering corner off the gas and should tighten entry. Saw a guy doing this Friday. Came into corner sliding all the way up the track then when/ if it caught he could get on the gas but he lost a lot of ground doing that
            • dirtracer07x
              • Aug 2014
              • 101
              Already down to a 525 on rf. I'm thinking I need to run the rear end straight up. Not trail the RR.
              • dirtracer07x
                • Aug 2014
                • 101
                Here's the plan for this week. Put a 550 in the rf, a 200 in the RR, run the rear end straight up, put a hold up shock on lr and lower jbar on frame 2in.
                • oldtrackchamp4x
                  • 270
                  You are planning on doing WAY to many changes on the car. You should only make one change at a time so you know if it works or not. If it doesn't work put it back where it was and try something else, if it works leave it where it's at and go from there. In reading your post that the car is good mid to exit, i would just try dropping jbar 1/2 inch on pinion or raising an inch on frame. JMO.
                  • dirtracer07x
                    • Aug 2014
                    • 101
                    Should jbar be level or lower then pinion on 9in?
                    • oldtrackchamp4x
                      • 270
                      As I said before, measure from center of bolt that attaches jbar to frame bracket and rearend side pinion plate bolt center wto the floor with all ride heights and tire pressures set. If rear end measures 6 in to floor and frame side measures 12 in to floor you have 6 inches of jbar split. Also as I said before, if car is good except for entry to middle, drop jbar 1/2 inch on pinion or raise frame side 1 inch. If the track is the same as the last time you raced it, you should feel the difference. JMO.
                      • dirtracer07x
                        • Aug 2014
                        • 101
                        OK I backed off on all the changes I was going to make. Checked measurements and had 8 1/2 ins of rake. Lowered it to 6in and set rear end square. That's it for this week. Thanks for the help.
                        • oldtrackchamp4x
                          • 270
                          Run the car as you now have it in hot laps, if you get hot laps, and see how it enters corner. If jbar is at center of pinion now and car is loose on entry lower it a 1/2 inch on pinion. If it is already 1/2 in below pinion go to an inch below pinion if car is really loose on entry, or raise a 1/2 in on frame if just slightly loose on entry. If you don't get hot laps and car is loose on entry in heat race the way you have it now and track will be the same in the feature or drier, raise 1/2 to 1 inch on frame or lower the 1/2 inch on pinion. JMO. Good Luck.
                          • dirtracer07x
                            • Aug 2014
                            • 101
                            It was really good in hot laps on tacky track. In the heat it slicked off some so I lowered RR bar to level. Main was super dry and car wanted to spin as soon as I got back on gas at mid corner. Think I will lower jbar at pinion for next week.
                            • dirtracer07x
                              • Aug 2014
                              • 101
                              Question. Is there an advantage to moving the RR spring on top of the rear end and if so what is it? Right now I have a 16" on slider behind but I see a lot of guys going to the 13" ontop
                              • oldtrackchamp4x
                                • 270
                                Remember, jbar is for entry to center. Did you raise lr bar? Did you increase your lr bite? If not you should probably try one or the other. You can drop your tire air pressures to 12 on the right side and 10 lf and 8 lr. On dry slick you really need to be VERY gentle on the throttle, or you could try a vacuum secondary carb. Keep good written records on how the changes effected the car and how dry or tacky the track was so you will know what changes to make to your car when it is dry or tacky. Again, one change at a time. And finally be honest with yourself and think about how well YOU did driving the car. JMO.
