What about putting a 2off wheel on RR? Now all are 3 offs.
Bmod setup help
Tighten car up mid corner on gas. I changed RR spring to a 200, raised RR bar 1 hole, lowered jbar 1 hole at pinion and the car was awesome.
Remember to keep notes on what the track was like and the changes that worked on that type of track. Sounds like you are good to go now. Good Luck. JMO
What front spring rates are guys running with chevelle clips? I have 625Lf 525Rf was told that is to soft and should go 700/600. Thoughts?
I have customers on 500-550 and 600-600 and 600-650, it really depends on your driving style and the amount of grip/banking your track has. If you enter soft or have a flatter dry track you can go softer than someone who enters hard and or races at a tacky high banked track.
