Rr top bar
  • hunterracing
    • Jan 2009
    • 303
    Rr top bar
    What are affects of to low rr top bar is there a point to low and take some forward drive way say 12 degrees
  • ambonci21
    • 63
    that's what we run and our car loves it. But im sure its a balance with the rest of the setup.
    • hunterracing
      • Jan 2009
      • 303
      Then if that's not it could be to soft pull bar rubber or maybe raise on reArend to get more overall tracing very exit
      • 25drtrkr
        • May 2015
        • 856
        too soft and/or wore out
        Lions don't worry about the opinions of sheep.
        • hunterracing
          • Jan 2009
          • 303
          Only getting 1inch travel and brand new middle hole bracket
          • washeduptoo
            • 1353
            How much preload do you have? It seems to me that we've run biscuits before that only got that much travel or not much more than that, not sure though.
            • hunterracing
              • Jan 2009
              • 303
              1/4 I was thinking pullbar but also thought maye rr top bar to low to drive off but other hand could jst be simple drop lrb down a hole and take some rear steer out
              • washeduptoo
                • 1353
                I would call who you got pull bar from and see what kind of travel yours suppose to get with the biscuits your running and go from there. Best of luck
