What are affects of to low rr top bar is there a point to low and take some forward drive way say 12 degrees
Rr top bar
Then if that's not it could be to soft pull bar rubber or maybe raise on reArend to get more overall tracing very exit
How much preload do you have? It seems to me that we've run biscuits before that only got that much travel or not much more than that, not sure though.
1/4 I was thinking pullbar but also thought maye rr top bar to low to drive off but other hand could jst be simple drop lrb down a hole and take some rear steer out
I would call who you got pull bar from and see what kind of travel yours suppose to get with the biscuits your running and go from there. Best of luck
