Shock Building
  • TwistedFrame21
    • Oct 2012
    • 54
    Shock Building
    What is a good way to learn the trade of shock building? I've always been curious, and been wanting to start building my own stuff for awhile. I just need a little guidance on the do's and donts. Any help is appreciated.
  • zeroracing
    • 1014
    There is some info out on the web by different manufactures. Depending on what brand you are going to work on. Bilsiten for example is very easy to take apart and rebuild if you can run a schrader valve.
    All of that said, your going to get very limited info on what your curve should look like and how to build that curve. Also anything short of a good dyno will have you struggling to make heads or tails of minor changes. Anymore you would want a higher level dyno that will measure zero force (rebound force as the shock breaks 0). The cheap pneumatic and pen paper graph styles struggle with this. Again, good luck to you but the few guys really in the know try to keep cards close to their vest.
    • turtle1hp
      • Oct 2014
      • 77
      I agree with zeroracing. A dyno is a must and not a lot of people are sharing information. I am in the early stages of building shocks and I find his statements to be true. I am also working with Bilsteins and building the machine to fill non Schrader valve shocks. I have been going back and forth with a rep at Bilstein and they are in the process of putting together classes. About a month ago they were saying that they should be starting the classes later this summer. I am wanting to attend. I will see if I can find more info on dates and locations if you are interested.
      Our Creed: "Where two or more are gathered, there shall be a RACE!"
      • TwistedFrame21
        • Oct 2012
        • 54
        I appreciate the honest replys, turtle I would definitely be interested. Keep this thread updated
        • RCJ
          • Nov 2007
          • 509
          Bilstein has charts of their shim stacks.Does any other shock company s do this?
          • zeroracing
            • 1014
            Ohlins x-stack does as well.
              As it relates to Ohlins, RE Suspension has some useful information on their website:
              http://resuspension.com/assets/Ohlins_X_Stacks Book.pdf
              Not sure how "current" it is but it's information at least.
              • turtle1hp
                • Oct 2014
                • 77
                When you say "charts" for the stacks, do you mean the dyno graph of the stack, or the shims needed to complete the stack?
                • zeroracing
                  • 1014
                  X-stack book has both, I am not sure how old the book is like Matt49 stated. It shows what the stack should graph like and what shims to use in what order. That said, even on a simple oil change I have my shocks ran on the Dyno to make sure they don't have some other issue or were installed incorrectly.
                  • Dirt_Buster
                    • Jun 2016
                    • 104
                    Finding a good flowing piston and properly done body is what we found to be the key. Also the way the piston seals against the body. Also we have tuned our shocks to be fairly the same most tracks and changed the bleed charectoristics for the low speed mainly. Hard to find a very good shock builder that knows anything and everything but we use one that's very good in my opinion and gets what we want exactly In the "feel" department everytime.
                    • turtle1hp
                      • Oct 2014
                      • 77
                      Ok. I have been trying to figure out how to ask these questions without sounding like a dumba$$.... "Good flowing piston" Is this to reduce cavitation at high velocity speeds? "Properly done body" and "piston seals against the body" Is this for the least amount of drag without losing low speed sealing/consistency? Is this something that you get in an upper level shock like JRI ?
                      • Dirt_Buster
                        • Jun 2016
                        • 104
                        ^^^ exactly. You'd be surprised how much smoke a lot of these shock builders will blow up your a$$. They better know about their shock and every other shock on the market and the pros and cons to them all. If they don't they're simply behind. Go ahead and ask them and if they can or can't tell you the difference of theirs and the competitors. If they can't then then I'd say they're not the best to go with.
                        • turtle1hp
                          • Oct 2014
                          • 77
                          That whole "smoke" thing is exactly why I started doing mine and my friends shocks. My friend has bought shock packages from a couple of different people and both sets came in labeled LF RF LR and RR. REALLY??? WTH?? How do you tune your car for different tracks and track conditions??? That's kinda like buying springs labeled LF RF LR and RR!!!!! Sorry.... Rant over... I try to understand how everything on the car works and the effects it can have on the corner speed. That whole "smoke" thing gets under my skin... I am "Financially Challenged" and can't throw money at things like some others can do.
                          • turtle1hp
                            • Oct 2014
                            • 77
                            I tried to contact my guy at Bilstein and he hasn't responded. He might be on vacation. I did go back through my emails and he stated that the classes would be in Mooresville NC hoping to start late July or early August of this year. As soon as I hear from him I will share the info.
                            • RCJ
                              • Nov 2007
                              • 509
                              Might do some search for build front forks or motorcycle shocks.I had found a web site for bikes that explained shim stacks very good.
