engine break in
  • m.lion
    • 60
    engine break in
    alcohol set up. which oil do you guys start a new engine with?
  • ToddSmith16
    • 2854
    If you have money to burn buy break in oil like Joe gibbs but if on a budget like I am I used rotella oil. To each thier own.
    • lovinlatemodels
      • 486
      We use are normal brad penn oil and add 2 quarts of zinc. Run in the garage bring up to 200 degrees let it cool down and change the filter and head to the track. But thats what we did.
      • Egoracing
        • 4852
        Used Rotella for YEARS but it is not the same as it was a few years ago, the EPA has required the removal of the zinc and phos in Rotella now also.
        • perfconn
          • 3636
          Unless it is a flat tappet cam you don't need to worry about breaking it in.
          • kencar87
            • Oct 2011
            • 44
            break in
            perfconn has got it right, noting special here, get some good 20-50 val. and light it up, run it for a while in the shop, drain and install new filter and oil, 20 -50 early in season , straight up 50 in the heat of the summer . I use val. and had good luck with it, around 4.75 a qt.
