I can shift my BERT into low gear, but it will not shift into high gear or reverse. The car isnt started, sitting up on jackstands. Shouldnt I be able to shift into all gears? Nothing is in a bind either
BERT shifting questions
Make sure it is actually in neutral.Originally posted by racinjason29 View PostI can shift my BERT into low gear, but it will not shift into high gear or reverse. The car isnt started, sitting up on jackstands. Shouldnt I be able to shift into all gears? Nothing is in a bind eitherWeb: http://www.t17.co
both levers were centered, I put it in low and back to neutral and couldnt pull into high, so I put it back in neutral again and no reverse, but I can go in and out of low
Check you shifter centered mite not be neutral in your tranny if you go just past neutral a little bit it can hold up the other shifter from working properly.
