let's chat
    • 2020
    #211
    Originally posted by brad hibbard View Post
    on this tranny subject---I just had a guy tell me that the 2nd gen bert has a chain inside
    I have a hard time wrapping my head around any trans with a chain inside being less friction but there is no doubt that the 2nd gen bert free's up some power to the rear wheels
    can someone expand on the internals of the newest BERT tranny to help me understand
    Brad
    www.race-1.com
    Brad, the first gen bert had a more std type trans cluster shaft but the shaft was 2 pieces with the clutch made into it. When the clutch was locked the whole cluster shaft turned similar to a regular trans. The 2nd gen trans doesn't really have a cluster shaft persay (its there but really small just for reverse if IIRC) the chain drives that small cluster shaft only when in reverse. Instead of a clutch pack, it uses a band for low gear instead of the cluster shaft with a clutch pack.
    Hope that makes sense.
    • 96racing
      • Nov 2010
      • 112
      #212
      I believe that is the way the Brinn Predator is also. When in high gear, it only turns the input and output shaft and not the entire gear cluster like the original Brinn trans does hence free horsepower.
        Originally posted by dirty white boy View Post
        a bit heavier than a burt/brinn over all, but lightest stock trans reciprocating weight trans i know of!
        https://www.youtube.com/watch?v=kEAaHjNuFV4&t=4s
        Thanks, that's the one ive been looking for. Someone awhile back, had posted that video!
        • dirty white boy
          • 1238
          #214
          its been posted in the street stock threads before a few times...other than over all weight and with a good light weight 5 or 7 inch clutch set up could work on a budget in right class, crates probably ant right class! maybe a limited late model tho'!
          white trash motorsports
          • brad hibbard
            • Oct 2007
            • 974
            #215
            thank you----makes perfect sense
              Brad, whats the difference between 602 and 604 carburetors? We got a great deal on a new Stealth that came with our car. It came off a 604 but were gonna be using a 602.
              • brad hibbard
                • Oct 2007
                • 974
                #217
                If you are using the same fuel as what the carb was calibrated for--there won't be any issues with running it on your 602
                to answer your question more directly about the difference in builds------
                it might be easier to start by explaining our focus with carburetors between the two engines.
                the 602 with it's dual plane intake and relatively small intake valve has quite a bit of initial power so we tend to soften the early side of the carb.
                The 604 needs all the help it can get at RPM's below 3500 so we typically focus hard on slow speed booster signal when used on a 604.
                the above is general description ---we do our best to customize the build to each engine combined with the situation such as car type and type of racing.
                That is why you cannot buy a carb directly from our website----we will always have a conversation about your situation before building the carburetor.
                Think of this:
                a pavement Late model
                a big tire street stock on dirt @ 3200#'s
                a 8" tire street sock on dirt @ 2800#'s
                a dirt late model with 4 link and open tire
                a dirt modified
                a pavement modified
                etc---etc--etc
                all of the above and dozens more run 602 and 604 engines ---there is no way possible to have a carb that works best in all types of racing
                fuel curve is relative to fuel type, altitude and weather not to the build/design of the carburetor
                hope that helps
                everyone stay healthy
                God be with us all
                Brad
                • brad hibbard
                  • Oct 2007
                  • 974
                  #218
                  We made the decision to close the shop to the public and all workers except me are working from home or just taking time off
                  I will continue to answer the phone and emails while getting a few things done in the shop, but (for now) we are not permitting anyone to drop off or pick up engines.
                  This virus has to be taken seriously by all of us to be defeated.
                  I don't know what to actually say except this is real and at first I was guilty of blowing off the seriousness of it but now I realize and hope you do as well that we have to be as cautious as humanly possible for awhile.
                  i am actually getting used to the smell of lysol---LOL
                  here is a tech tip:
                  I have not done the research to confirm this but it comes to me from a very reliable source
                  hydrogen peroxide ---kills the virus on surfaces including our hands (instantly I'm told)
                  peroxide is cheap and readily available and does not feel sticky or nasty to the touch and it really has no smell.
                  I intend on doing a little homework on it but I thought some of my 4M family might have some info as well
                  stay healthy
                  Brad
                  • CCHIEF
                    • Jul 2014
                    • 399
                    #219
                    If you think the parts cleaner tank dries your skin, wait til you use H2O2, all that dry skin will be gone, hopefully there is enough wet stuff underneath! Save it for surfaces! Lysol smells like a prison.....Which your sorta in! So many not taking this serious is why we are where we are.... Corona Virus leader in the world, not the lead we need or want to be in. Stay healthy, the racing world needs us 'old' guys!
                    • brad hibbard
                      • Oct 2007
                      • 974
                      #220
                      you threw me a bit with the chemical code (H2O2) ---LOL but it was an easy find
                      anyway I did a little research on my own and found that Peroxide (H2O2) is effective on the virus but the recommendation is to leave it sit on the surface being treated for 5 minutes before wiping
                      with that bit of information I retract my previous comment of "instantly"
                      Chief--I might be a little more resistant to dry skin (because of all the parts cleaner time) but it really doesn't seem to dry my skin out to a point of concern
                      maybe lets consider another use other than skin
                      I deal with boxes on a daily basis ---and God only knows where they have been
                      Reports are that the virus lives for at least 24 hours on cardboard
                      My procedure for this past week has been to spray down the boxes with H2O2 and leave them sit outside for 24 hours under our porch roof
                      I feel bad for delivery drivers ---IMO they are as much at risk as health workers
                      try to understand their position when they deliver to you
                      Brad
                      • brad hibbard
                        • Oct 2007
                        • 974
                        #221
                        Happy Easter to my 4M family
                        it's a sad time in the world but the celebration of Easter is AWESOME!!!
                        Brad
                        • brad hibbard
                          • Oct 2007
                          • 974
                          #222
                          hope everyone is well ----looks like we can see some light towards slowing the virus and getting back to a more normal life-----I hope they don't rush the openings and and spin us out -----we need to move slow and easy---just like slick track driving----"slow down to go fast"---most of you know what I mean
                          stay safe---stay healthy
                          Brad
                          • brad hibbard
                            • Oct 2007
                            • 974
                            #223
                            any feed back on 2 barrel carb adapters for crate engine
                            more related to 602 but for discussion if you have 604 information ---let's hear it also
                            Brad
                            • rjs21
                              • 37
                              #224
                              Hey Brad, curious if you've had any experiences with the flat air cleaner bases that I'm seeing around. Any benefits or drawbacks to them? We run claim IMCA Sportmod engines on a Holley 4412. But interest in looking into them if they are worth what they are worth.
                              Shop Now for the Best Race Car Parts for your GM Crate Engine. We also offer Tech Tips and Videos.
                              • brad hibbard
                                • Oct 2007
                                • 974
                                #225
                                our flat base version is similar to what you are speaking of
                                we have been testing with it and using it for quite awhile---there are some down sides to it and walker engineering has addressed the negatives to the crate innovations flat base with positive gains
                                The Walker system is "nearly" the same power numbers but takes the dips out of the acceleration rate that we see when the flat base is introduced to moving air.
                                We have recently performed some high speed air testing on the dyno with both the Walker System and the Crate Innovations flat base----we are currently organizing the information from the test sessions and will have it available soon.
                                To answer your question more directly
                                YES---we use it and hands down it has made the most power and TQ than anything out there when comparing static dyno numbers
                                stay safe and stay healthy
                                have a great day!
                                Brad
