let's chat
  • doyle hargraves
    • Jul 2009
    • 158
    #76
    Thanks billet!!
      • 2020
      #77
      "The primary bowl (on the right) actually had a top feed n/s with a .250" needle size and the secondary was a normal top feed .110". The primary n/s was run at 2 psi (low psi-hi flow) while the secondary was run at 6 psi"
      Start at about 11 seconds in and set to .25 playback speed in setting at the lower right hand of video. PSI is all related to the size of the N/S. 2 PSI kept the front bowl full. . . .2 PSI (Grins)
      *Note the front of the engine is too the right in video
        • 2020
        #78
        https://www.youtube.com/watch?v=PehQUKwQX8E STD top feed .150 N/S
        https://www.youtube.com/watch?v=FOJKcvTKQAg Bottom feed .150 N/S
        run at .25 speed and see the difference, the STD bowl is almost 100% foam
        • brad hibbard
          • Oct 2007
          • 974
          #79
          Mr. birdcage
          you are certainly cutting into my sleep time--LOL
          thank you---I am paying attention
          Brad
            • 2020
            #80
            HMMM, not sure if all of the wix stuff is gonna be made in mexico or if it means any changes in quality but worth some research
            • doyle hargraves
              • Jul 2009
              • 158
              #81
              Been running wix paper air filters on my sons crate motor and thought they were doing a decent job. Took motor in for freshen and engine builder says it has been breathing some dirt. Says it has some abnormal cylinder wall and ring wear and he needs to hone it and install what he calls high limit pistons. Not sure if the problem is wix or just paper filters in general? He suggests walker Guess I’m gonna try them.
              • doyle hargraves
                • Jul 2009
                • 158
                #82
                Forgot to mention we always grease the filter to base area and use a sure seal on the carb to base so don’t think the problem is there
                • doyle hargraves
                  • Jul 2009
                  • 158
                  #83
                  Just thinking about this fuel bowl thing. I wonder if anyone has ever tried a fuel bowl setup with the n/s on the bottom??
                  • brad hibbard
                    • Oct 2007
                    • 974
                    #84
                    I caution you on your engine builder's piston selection.
                    there are no crate sanctioning organizations that I am aware of that permit a high limit piston
                    the Walker filters will do a great job for you
                    Brad
                      • 2020
                      #85
                      Braswell did one as an experiment, not sure it ever went far enough to become a product or why it was abandoned
                        • 2020
                        #86
                        Generally as long as it was a good paper filter (with the wix you are good) it's the base that's tweaked and not sealing like it should.
                        • fastford
                          • 4059
                          #87
                          i never could bring myself to trust a paper filter , still swear by the ole k&n that you wash and spray , i did learn that you can spray them with type f trans fluid and clean them with white wall tire cleaner and it worked just as well as the expensive k&n kit....
                          • Jking24
                            • Oct 2017
                            • 1516
                            #88
                            Not in reference to crates but latemodels in general and specifically steel blocks. Methanol vs gas vs e85 pros cons, tune sensitivity?etc....
                            • brad hibbard
                              • Oct 2007
                              • 974
                              #89
                              this should take a page or two of opinions--
                              the gas family of fuels has to be broken up into at least 2 categories---oxygenated and non oxygenated and in the 9 to 1 world we have to also talk about pump gas which is actually an oxygenated fuel but we do not treat it like an oxygenated fuel because it won't tune like an oxygenated fuel
                              for now let's leave pump gas out of the conversation
                              my responses will be general for now and based primarily on the 9 to 1 crate engine
                              for torque we will always choose methanol
                              the exception would be in unusually cold conditions
                              the down side is the maintenance involved
                              most chassis guys will not want you to use it because of rapid change in percentages
                              E85---awesome fuel
                              BUT --it's not a lazy mans fuel ----constant content checking and adjusting is required
                              E85 runs best in high heat and humidity ---
                              a specific "purpose built" carb is needed -----there is much more to it than jets
                              Non oxygenated gas
                              very friendly fuel for our engine and fuel system
                              detonation is rarely a problem
                              corrosion is not a problem
                              stores easily without special containers
                              lacks in power and acceleration
                              oxygenated gas
                              makes great power in cooler temperatures
                              easy to tune----accelerates well in most conditions
                              very corrosive for valve guides--piston rings--carburetors and regulators
                              storage can be an issue---short shelf life
                              stinks and costs alot of money
                              that should be enough to get the ball rolling
                              Brad
                              • Jking24
                                • Oct 2017
                                • 1516
                                #90
                                In reference to e85 you say constant checking and adjusting. I am aware that you need to check it for correct content care to elaborate on the adjusting part. Jetting or actual fuel mix
