let's chat
  • fastford
    • 4059
    #46
    i have to say i appreciate what our track has done with the street stocks and the new modified class , no more sanctioning body,s , just track rules , you can run a 602 , or build your own engine and pull extra weight , and i am good with this......
    • RW57
      • 662
      #47
      Glad to see some tracks are open minded about this that's a step in right direction.
      • dirty white boy
        • 1238
        #48
        and on a protest, motor gets dyno'd, if it shows more power than a 602 should it gets tore down, if it dont dyno high it gose back to owner as is!
        white trash motorsports
        • brad hibbard
          • Oct 2007
          • 974
          #49
          here is my problem with dyno tech
          what is the base line?
          what bolt on components are being used for tech purposes?
          are you only looking at peak TQ and HP ?
          I have been involved with dyno tech in the past and always recommend a stand by (known legal) unit be run just before the engines in question- and be run with all the same components and timing (absolutely the same exact fuel)
          the values of TQ and HP be looked at in several different RPM levels
          the point at which TQ and HP cross is a key number
          IF the engine in question is above base line numbers ---give the owner the opportunity for tear down and inspection by dimension and volume
          not to many tracks or sanctions want to go through all that but how else can you be accurate?
          Brad
          • RW57
            • 662
            #50
            My question is it it's a clone carrying an extra 50# and is duplicate of 602 how can it make more power if it checks right. Again I'm saying first teardown is on me no money taken i would be willing to pay tech guys 75 or 100$ fee he gets to tech a motor then he seals other head oil pan timing cover or something of way to id engine I put it back together for 100$ or so .Next time though it's regular protest fee. Problem is at my track protest fee does not cover reseal fee. Happened twice to a friend of mine to reseal a 602 . He had to pull money out of his pocket to cover rebuilders fee . How the hello is that fair it's not.,I just trying to figure out ways to keep people racing.
            • fastford
              • 4059
              #51
              IMO a built engine has no place being teched by a dyno , its the physical aspects you tech , ie: heads , block , cam , pistons and so on , not numbers on a machine...
              • RW57
                • 662
                #52
                Excellent point Fast Ford.
                • 96racing
                  • Nov 2010
                  • 112
                  #53
                  Brad, I have a new question that I'm interested to learn about pertaining to the 604. Which carb spacer makes the most power on the dyno and which one do you recommend? And where would that power benefit you the most ie. better restarts, more topend on big tracks etc.
                  • brad hibbard
                    • Oct 2007
                    • 974
                    #54
                    this might take a couple of posts because I am kinda busy right now but have a minute here at lunch so i will start the explanation
                    when you say "power" that term is most commonly associated with HP and even more specific peak HP
                    to me peak HP means absolutely nothing but a plain open carburetor spacer will hands down produce your most peak HP
                    with that said why do we have so many different configurations?---answer
                    torque, acceleration and drivability
                    when we cut space down with a simple 4 hole ----we increase acceleration but loose HP
                    when we add anti reversion under the spacer---we increase acceleration and TQ and gain some HP back
                    when we cut height ---we gan torque but loose HP
                    in the 4 link world of dirt racing the attitude of the car is to be tipped onto the RF corner
                    this off level situation combined with natural G force creates a much higher jet pressure on the right side and also has a tendency to spill fuel out of the vent tubes
                    this can be countered with an angled spacer
                    I was just getting going here---gotta go ---hope to return later with more input
                    Brad
                    • brad hibbard
                      • Oct 2007
                      • 974
                      #55
                      little calmer now---
                      let me start this reply with there is NO perfect carb spacer for a 604
                      carb spacers all do different things and the best thing you can do is get a good balance for your situation.
                      for dirt late model applications we do like an angled spacer--most of the time (not all)
                      we have been very successful with this particular one
                      it does meet the 1 inch rule that is in most sanctions and is a second version of the original
                      the original had too much angle and some other bad charcteristics
                      our goal is the best drivability meaning the smoothest power without hesitation
                      sometimes and in some areas of the track we may be giving up a digit or 2 of power but raw power is rarely what wins a race
                      we have to work with many different rule books and many different series so I can comment on quite a few different spacer combinations if you have one in particular
                      1 inch lightweight HVH super sucker is our "go to" spacer when we do not have much information but given specific situations we will change that up
                      hope some of that helps---sometimes I confuse more than explain--LOL
                      Brad
                      • RW57
                        • 662
                        #56
                        Optimum carb size for 602 and 604. Guys around here are going to 650s because they say engine is much more responsive off corners. I know on my claimer type engine it even sounds better with 600 single line Holley than when I bolt on my 750. Both are on e85.I think a 650 would be ideal for it. This was what my Carb builder were talking about. He was the Legendary Smoky Joe Summerville who passed away last week I am still reeling from this. He always took care of me on my carbs and stuff gonna miss him. Give me your thoughts on this.
                        • fastford
                          • 4059
                          #57
                          sad to hear this , he was on top of the game in his day , as for the carb thing , right out of the box , i think a 650 will perform better , especially at lower rpm,s , but in the long run and if you can afford them , one of these tricked out , modern 750,s built for a crate engine in particular , will perform circles around it....lmo....
                          • 96racing
                            • Nov 2010
                            • 112
                            #58
                            Most of the Stealths are 700 cfm and the Bakers are 750. That is what most guys around here are running. We had good success with one of the old 750 Stealth carbs that had the extra 1/2" spacer between the body and base plate but we run big half mile tracks. Also ran the 1" HVH spacer but had more success with it upside down. Sounds crazy but 602s already have plenty of low end with the short dual plane intakes. I'd guess it moved the power more toward top end where it was needed. Might have just been the combo with that carb. Tried it on a 604 and it didn't like it.
                            • 96racing
                              • Nov 2010
                              • 112
                              #59
                              Brad,
                              We run a RUSH 604 dirt late model. Mostly interested in comparison between the 1" HVH that everyone runs and the newer 5/8" to see which would be the most beneficial.
                              • brad hibbard
                                • Oct 2007
                                • 974
                                #60
                                the difference between the two HVH spacers is a trade off
                                the shorter 5/8" has a little more snap on restarts but is lacking just a bit midtrack in comparison to the 1 inch
                                we always like acceleration rate the most so we generally go with the 5/8
                                you are not gonna see a big difference either way from the seat
                                Brad
