in response to your power numbers---
watching that peak HP # is OK but watching how long it carries is more important
also don't get caught up in only peak #'s
we look at HP and TQ at 3500--4500--5500 and 6200
6200 is NOT my recommendation for target RPM but we use it in evaluation
my recommended target RPM is 6000
we need quite a bit more information to say if your number is "good"
example:
put it on methanol with a stepped header and torque plates and a 750 carb it is ticking the 400 HP #
but come back to the real world of gas --650 carbs and 1 5/8 headers and we are talking 353
we evaluate every engine with the same components including a very specific fuel ---our air is closely controlled
it is absolutely amazing how close the engines are when done that way
your buddy that paid a premium for a blueprinted motor may or may not have been cheated
depending on the year ---many engines are so close to the performance side of the spec that you can't do anything other than give it a good hone job and put some bearings in it
now if it truly hadn't even been pulled apart that would be a good reason to be upset
Brad
example:
Brad
