I am needing setup information for my mastersbilt by mars late model. Was told to speak with Cody Mahoney and need contact information for him. Any help would be appreciated
Needing setup information on 2010 mastersbilt by mars late model
I know they shipped to Mars with some of the mounting points out of the car. But don't know all the details. No details from the previous owner?Originally posted by Hoyt3383 View PostWas told by mastersbilt that mars moved a bunch of stuff around on my type of car. And that I needed to talk with mars. Called mars and they said they couldn't get me and paperwork/ setup information on the car.Modern Day Spec Wedge Racing
I think they was sent to Mars with no cross member and no 4-link mounts, but there could be other things as well. I don't remember dates but 2010 would likely be too late or one of the last masters by mars as they started building Mar's cars around that time. I guess it's possible they still did the masters by mars for a while after they started building the Mar's cars so......Originally posted by MasterSbilt_Racer View PostI know they shipped to Mars with some of the mounting points out of the car. But don't know all the details. No details from the previous owner?
I'm just not sure of the exact time line on those cars but to me it's possible it's older or a mars car.Last edited by billetbirdcage; 04-05-2017, 05:46 PM.
Someone has to know about this car . I need ride heights, spring rates, jbar length and rearend location. Jbar height on frame and pinion. 4-bar locations (which holes on the chassis. Has the 7 hole 4bar brackets under it. Round tube overrail car. Wants to pack the LF wheel and wants to spin out and blow the rear tires off of it.
3 wheel and spin out?Originally posted by Hoyt3383 View PostSomeone has to know about this car . I need ride heights, spring rates, jbar length and rearend location. Jbar height on frame and pinion. 4-bar locations (which holes on the chassis. Has the 7 hole 4bar brackets under it. Round tube overrail car. Wants to pack the LF wheel and wants to spin out and blow the rear tires off of it.Modern Day Spec Wedge Racing
No not a new driver. Car has 147lbs bite. Jbar is 9 1/2 up on frame bottom on pinion mount. LF 500, RF400, LR200, RR 250. 5th coil 325 spring. When ever I'd drive the car into the corner on the throttle it would dump on the RR , and couldn't get back on the throttle the way I needed to before it would spin out. On restarts car would kick out the RR and spin the rear tires
Does the car turn into the corner ok? 400# spring on the rf seems to heavy. If the rf is too heavy, and the car does not roll over on the rf and stay there through the middle of the corner, it is going to three wheel on exit. This sounds like a tight car that is not turning in very well.
All his springs are in range for a smack down car with a vanilla setup from that timeframe.Originally posted by LRtireCHANGER View PostDoes the car turn into the corner ok? 400# spring on the rf seems to heavy. If the rf is too heavy, and the car does not roll over on the rf and stay there through the middle of the corner, it is going to three wheel on exit. This sounds like a tight car that is not turning in very well.Modern Day Spec Wedge Racing
Spins out before you pick up gas, but tight in? Wheel spin, but 3wheeling? I can be no help here.Modern Day Spec Wedge Racing
