Have 2011 Gen X Mastersbilt. Car absolutely sucks in the slick. Recently added a LR traction shock, no help. We’ve indexed the birdcage, moved 5th coil, moved bars etc, car still terrible in the slick. It’s like the car stays on top of the track, will not plant the tires.SpringsRF 300RR 250LF 500LR 175
Mastersbilt Gen X HELP!
You haven't told us what your actual handling problem is which would be helpful.
That being said, if you're taking big swings at it and nothing is helping you, something is fundamentally wrong like scale number, something bent, something in a bind, etc.
And this may sound crazy but check your tire pressure gauge.
Right kooser , a 375 rf on an MB1 oil shock with a pair of 225’s on the back with a 12†drop straight from the 2011 set up sheet Panhard at 8.5 center on the pinion rear bars square and and he’ll broom the xr1 / long horn / club 29/ sweet Bloomquist cars with the stuff they have worked on for the last 8 years .... especially when it gets slick ....
Yes that is correct. I don’t think the set up sheet changed from like 2008. Driving off the corner was not their strong suit even back in 2011 against the other 2011 stuff. I have a brand new 2012 sitting In my garage that I bought and built in 2012 but never raced. I might run it this year. The first thing I will do is build an underslung to make the chassis more rigid so it responds to adjustments , change the tube lengths and the left rear 4 link mounts and I honestly think the car will be good with 2018 shock technology.
Masters was very clear at their seminar that the car will be it’s very best the first night and go downhill from there. Having a fexible race car allows you “ room for error “ I guess but it also doesn’t respond to adjustments. I plan to add a few more bars in addition to the underslung. The front has a decent amount of clearance I will just shim the bump spring to go solid before the frame hits. It’s a really nice car that I spent a lot of time building and it’s wOuld be a shame to never race it lol
We have two smackdowns, and I hope the Gen X has better clearance from bottoming. The stock one bottoms at 2 3/4†and the one we raised the cross member on will go to just shy of 4†on the RF. Just dealing with that was a big improvement on updated shock and spring setups.Last edited by Nesmith14b; 10-19-2018, 05:20 PM.
