Axel tube lengths
  • hunterracing
    • Jan 2009
    • 303
    Axel tube lengths
    Has anyone played with different axel tube lengths for different cars. Like some
    Say 33/34 or 33/35 and go to 32/35 or 32/36 and offset it to left more
    In car
    • 14324
    In car
    Yes. It is a similar result as moving the pullbar on a car that has one. There is also j bar effects, if you don't correct for that. Longer rr tube means less j bar load to rr.
    • hunterracing
      • Jan 2009
      • 303
      Ok I was kinda assuming shorter lr tube would favor lr more but I get what your saying bout longer rr tube
        • 14324
        It does favor it for drive off corner.
        • over4T
          • Feb 2015
          • 1108
          Also "adjusts" your pinion and driveshaft angles, probably not in a good way.
          • keeks
            • Oct 2008
            • 687
            How does it affect that?
              • 14324
              I disagree about pinion angle, but driveshaft angle, when looking from above, does change.
              • fastford
                • 4059
                i guess you could say pinion angle in relation to drive shaft angle and not the ground....jmo...
