Left Rear Front Shock, Yes or No???
  • Cranky
    • Sep 2014
    • 174
    So what is the opinion on LRF shock? Is everyone running them? Are people going away from them and just running a chain limiter? Pros and cons of each and in what scenarios are one or the other best to run?
    • 14324
    No matter how many shocks you have, a chain limiter is need because shocks are not meant to be limiters.
    Number of shocks is preference. If you are good at keeping car on bars, front shock not needed
    • Matt49
      • 3123
      Agreeing with MB that your shock(s) should never be a travel limiter.
      1) Bad on the shocks
      2) Travel limit changes with bar changes if you use anything mounted to the birdcage like a shock
      Use a chain to the axle tube...that's the best way.
      MB is also right in that a shock in front is not needed if the driver can keep the car on the bars. That being said, Bloomquist, Owens, and many other top drivers use a shock in front of LR...so go figure.
      • Drop Shock
        • May 2012
        • 821
        Davenport says no
        • fastford
          • 4059
          since getting on the soft rt front set up, we have not needed it.
            • 14324
            Originally posted by Drop Shock View Post
            Davenport says no
            Not when you have the "Rumley device"
            • 7uptruckracer
              • May 2009
              • 1336
              Saw pics of it.....Pretty interesting.....
              • fastford
                • 4059
                where can you see these pics ?
                • 7uptruckracer
                  • May 2009
                  • 1336
                  Saw it on a track photographer page yesterday but they have since been removed.......I'll see if i can hunt it down. I know of someone who is trying to duplicate the birdcage assembly right now but there are rumors of it being banned
                  • PushinTheLimit
                    • Apr 2013
                    • 465
                    I seen a couple of pics on facebook of his left rear... but I didn't see much in that picture. Must've been a better one than that one.
                    • fastford
                      • 4059
                      I found those pics as well. all I could see is what looked like a shock of some kind coming down to what looked like the center of the axle on left side instead of in front of axle.
                      • PushinTheLimit
                        • Apr 2013
                        • 465
                        Yep, I did notice that as well.
                        • 7uptruckracer
                          • May 2009
                          • 1336
                          I saw Gene's and a friend that was there had a pic he sent to my phone but I didn't save it .
                          • Dirtmod13
                            • Jan 2014
                            • 245
                            Someone got a pic of it at cedar lake nationals. Seemed like the pic was too good for it to be a bystander though. Maybe he put some fake parts on there then took a pic to have circulated around to screw with everyone.
                            • Matt49
                              • 3123
                              I haven't seen any pictures. I believe they have some sort of cantilever system that is applying load to the LR axle tube (via the coilover that everyone is seeing) as the car rolls to the right. So as the car rolls, instead of the RR spring taking all the weight, some of it is getting redistributed to the LR.
