Roll over on right rear
  • oldtrackchamp4x
    • 270
    Why are you worried about chaining the lr? A lot of fast guys are doing just that.Just adjust chain until you find what works on your car, 1.5- 3 inches. Works for me. JMO.
    • 7uptruckracer
      • May 2009
      • 1336
      Does your shock have a schrader valve? Check your gas pressure if so. You could also be to soft on your pull bar whats your angle on that? 90/10 on it?
      • Dirtrunner35
        • May 2010
        • 632
        Originally posted by hockey3266 View Post
        My car already has all the things they mentioned have the rr cage indexed at 0 rr upper bar angle is at 18* and you dont really want to go under that. and my shock isnt dead..... roll steer isnt really what im after because if i fix the problem the car will create roll steer....When i pick up the throtle in the corner the rr picks up like the left rear instead up digging creating side bite and roll steer...Since the rr is jacking up im losing roll steer...thought about chaning down the rr but really didnt want to have to do that!!!!!
        So you are wanting more side bite because ???
        • let-r-eat
          • 2319
          I think he wants more roll steer and he isn't getting it because the RR is jacking up with the left rear. Could be a million things wrong.
          BUCKLE UP NOW, YA HEAR?
          • hockey3266
            • Dec 2010
            • 65
            ^^^^^^ LOL everyone is anaylizing this wrong i want the car to stay on the right rear!!!! which will create more roll steer and side bite.... i know how to get more side bite and roll steer i want to know how to keep the rr planted when its in the corner....and yes i have a schrader vaulve but its a base vaulve shock i only run 20-30psi
            • hockey3266
              • Dec 2010
              • 65
              here is a link to what my car looks like in the corner https://www.facebook.com/?ref=tn_tnm...type=3&theater
              • 7uptruckracer
                • May 2009
                • 1336
                I'll be at Clarys this weekend. Have you talked to Brett about the car isnt it a Hamilton? More rebound in the RR will keep it down. Your lower on gas pressure then I would have guessed. You can run less compression and more rebound will free entry and tighten exit. What are you clamped in front on spring on top?
                • Dirtrunner35
                  • May 2010
                  • 632
                  put it on z link on the right then
                  • hockey3266
                    • Dec 2010
                    • 65
                    This isnt a true hamilton we changed the rear suspension and also all the hamilton cars do it lol thats y im on here.
                    • hockey3266
                      • Dec 2010
                      • 65
                      and no we arent clamped we are on the birdcage spring beind lr and spring in front on right side
                      • 7uptruckracer
                        • May 2009
                        • 1336
                        I don't know if Ive seen you run Clarys before I've been trying to help a few out there but pretty much stopped now for various reasons. I just went through the 17L the other week and changed him to a 4bar Jbar. If your hiking the RR to much it means you have a lot of thrust angle or you need more control over what might limit your hike like rebound or compression. Some suggested the RR chain its not a bad idea we run it on the LM to help in the slick but Clarys doesn't really get slick it keeps the car from hiking the RR so your not gaining bar angle which results in less thrust angle and less drive so a tighter car. If you have a 3-5 or a 4-6 shock maybe try that. Check all your Pull bar preload and your springs in it It could be hiking the whole rear but your just noticing it as a RR problem because they left normally hikes. What is your RR spring?
                        • hockey3266
                          • Dec 2010
                          • 65
                          200 RR spring and the pullbar angle and preload is all correct ive talked to many people they said try channing down the car on the rr....Yes i will be losing some drive but they also said by channing it down i will entire the corner better, which will result in a better exit....
                          • clbaker25x
                            • Oct 2013
                            • 85
                            Everyone is giving you the chain answer. Is there a reason you don't want to chain down your right side? Chain is cheap. If you don't like or it causes another problem you can always take it off.
                            • hockey3266
                              • Dec 2010
                              • 65
                              I did plan on channing it but most cars dont need the chain so i was trying to figure out what would be causing the hike up on the rr? That was the point of this thread.
                              • clbaker25x
                                • Oct 2013
                                • 85
                                When I went through manufacturers row at Boone almost every car had the chain on the right side. I talked to John Saathoff about why he doesn't run one on his car. He said that he did have a problem with this at one time, but they move the birdcage out a little (towards the wheel) and that eliminated the hike on the right side. He didn't tell me why he thought the car was going up, but said that was how he got his car to not do it. Jet cars are on of the ones that don't normally run a chain on the right. Might give that a shot.
