Question on mods
  • Bob Hubbard
    • Aug 2008
    • 1048
    Question on mods
    Im a newbee to racing and while looking at new mod chassis I heard two different opinions ? One builder says he likes bump stops .....They do not ? ( meaning another chassis builder ) What does this mean ?
  • HEAVY DUTY
    • 796
    Personal feel. They both will work. The bump rubber allows you to run a softer spring. The bump stop adds spring rate as you start to compress it. The bad thing about bump stops is that they are very progressive in rate, and some get too stiff too quick. Advice for a using bump stop is, use the tallest, softest, Christmas tree style ones that are more linear in rate, and run a fair amount of shaft showing before you get on the bump stop. That way the car gets enough movement before the rate gets too stiff. If your car is good on no bump stops, your sweet spot is bigger. Bump stops, especially stiff ones are hit and miss. Don't use them on rough tracks other than to stop the travel at the very end, to keep it from bottoming hard ( metal to metal )
    • Bob Hubbard
      • Aug 2008
      • 1048
      Thank you for making that easy t understand ... I have alot more questions but for some reason that one was first ....LOL Thanks again
      • dirtracer07x
        • Aug 2014
        • 101
        some classes dont allow bump stops i believe. what sanction will you be running?
        • Bob Hubbard
          • Aug 2008
          • 1048
          Im just helping a friend search info .... UMP mod rules
          • lilsumo
            • Jul 2011
            • 154
            if your looking for a chassis, call Heavy Duty. He builds a fast car and his customer service is the BEST
            • Bob Hubbard
              • Aug 2008
              • 1048
              We have picked a chassis builder hope this year will be better now that we have tech support ..... Another questions are shocks ? Do we buy 4 or 6 ? Ive heard rf & lr are the most often changed ? Thanks for any imput as were just looking for info ....
                • 14319
                You are 100% correct! Only chassis builder in any type of car that I have found willing to talk longer than me! Lol
                • 25drtrkr
                  • May 2015
                  • 856
                  Is he the owner of Lightning Chassis? If not, what is his brand?
                  • racindirt8p
                    • Jan 2014
                    • 43
                    Yes heavy duty is Don owner of lightning chassis great cars and awesome tech always willing to help
                    • Bob Hubbard
                      • Aug 2008
                      • 1048
                      We need a set of scales this year ..... What should we buy ....
                      • Bob Hubbard
                        • Aug 2008
                        • 1048
                        Whats the most affordable way to have a 650 hp motor built .....
                        • save the racers
                          • May 2013
                          • 271
                          355 CID spec head motor.Angle mill the heads ,2925 intake, roller cam.3.5 stroke crank is easy to drive and not as hard on parts.You can use a stock block with splayed caps.If you are new to racing I would get a 355 with angle milled vortecs ,solid cam.Pro products intake. Use 1.6 exhaust valve' port the exhaust, leave the intake stock.
                          • Bob Hubbard
                            • Aug 2008
                            • 1048
                            Can this kinda h/p be bolted together without have to go thur a engine builder & machine shop work ?
                            • save the racers
                              • May 2013
                              • 271
                              It depend on your skill level and the tools you have.The balancing, boring, decking,align bore,milling and valve job are machine shop work you will have to have done.As you go up in h/p, the tougher it gets.
